Shapefile filtering breaks with an apostrophe
969
12-06-2023 02:19 PM
GeoffroyRicher-Lalonde
Hello. We found out that Shapefile filtering breaks if the attribute contains an apostrophe.
The Shapefile not filtered (139 different characters were tested):
The Shapefile correctly filtered (an example):
Unfortunately, the Shapefile filtering breaks if we use the apostrophe:
This character is very common in French language, so we encounter it often. I added the Shapefile I worked with in the ZIP file attached.
Thank you!
Geoffroy Richer-Lalonde
GIS Specialist, Hydro-Québec
Lexie
Hi @GeoffroyRicher-Lalonde ,
Thank you for your feedback. The French user experience is crucial to us. We'll prioritize addressing this issue in the upcoming version and keep you updated promptly.
Lexie
