Georeferenced TIF is off in longitude by 1/3 of a degree
1312
06-17-2025 01:39 PM
GeoffroyRicher-Lalonde
Here is a download repository of georeferenced TIF for this bounding box:
  • North : 46,125 N
  • South : 46,0 N
  • East : 76,0 W
  • West : 76,25 W
https://diffusion.mffp.gouv.qc.ca/Diffusion/DonneeGratuite/Foret/IMAGERIE/Produits_derives_LiDAR/31K...
When I download the shaded DTM (MNT_Ombre_31K01SE.tif) and add it to ArcGIS Pro, everything is fine. The TIF is well georeferenced:
But when I add the same TIF to ArcGIS Earth, the raster is off in longitude by exactly 0.3333 degree:
There is no error in latitude. This bounding box and this TIF is just an example. Any other TIF of any other bounding box will have this 0.3333 degree error in longitude. Why does the TIF is OK in ArcGIS Pro but off in ArcGIS Earth ?
Thank you.
Geoffroy Richer-Lalonde
GIS Specialist, Hydro-Québec
Pål_Herman_Sund
Interesting differences between Pro and Earth when it comes to interpret EPSG:2951
Pro
Earth
So Pro interpret the EPSG code and does a CM og -76.5. Earth provide a EPSG code of 0 and a CM of -76.8333. I would log that as a supportcase.
br
pH
Thank you @Pål_Herman_Sund for these explications !
Pål_Herman_Sund
Always supporting nordic skiers @GeoffroyRicher-Lalonde 😄
cheers from Norway
The same 1/3 degree problem has been identified with EPSG:32198. The central meridian should be -68.5 not -68.8333333333333
Pål_Herman_Sund
Shall we do a search in the epsg database to find all CRS's using a ".5" meridian or parallel @GeoffroyRicher-Lalonde ? 😉
