Building a High-Resolution World Basemap for Hosting on a Private Server
1554
12-27-2024 08:00 AM
AlbertoMisrachi
Hello, ArcGIS Pro Community,
I’m looking to create a world basemap at the highest possible resolution using ArcGIS Pro or other Esri tools and host it on my private server. The goal is to achieve detailed, high-quality imagery with global coverage, optimized for zoomed-in levels.
Key Question:
  • What is the recommended workflow or setup for obtaining and exporting tiles from Esri’s World Imagery or other high-resolution datasets in ArcGIS Pro?
I want to ensure the process adheres to Esri's best practices and licensing requirements. Any advice on the appropriate tools, settings, or documentation would be highly appreciated.
Thank you!
ThomasHoman
First off - check with your esri sales representative for all the proper things.
Second - Have you done calculations for the amount of expected storage needed? Google suggests the surface area of the earth is 510 million square kilometers (5.1E+08 km2)
  • Dropping in at 1meter resolution moves that number to 5.1E+14 square meters or the number of 1m pixels worldwide.
  • Adding the 3 bytes for RGB brings us to 1.53E+15.
  • 1 TB of storage is 2^40 bytes (not the marketing 10^12 so you would need roughly 1,400 TB of storage of 1m resolution.
If you are shooting for 30cm/1ft resolution then your storage goes up by a factor of 12 to around 17,000 TB.
Just something to consider in your journey.
Good luck
Tom
AlbertoMisrachi
Thanks Tom,
Yes I have made the calculations for storage, excluding Oceans:
Storage Calculation:
  • Including Oceans:
    510,000,000,000,000510,000,000,000,000510,000,000,000,000 pixels × 3 bytes = 1,530,000,000,000,0001,530,000,000,000,0001,530,000,000,000,000 bytes (1.53 petabytes).
  • Excluding Oceans (Land Only):
    149,000,000,000,000149,000,000,000,000149,000,000,000,000 pixels × 3 bytes = 447,000,000,000,000447,000,000,000,000447,000,000,000,000 bytes (447 terabytes).
Also efficient tiling strategies and compression.
The blocker now is the source of the images, or the cost not exceeding 6 figures.
