Are there step by step instructions for configuring the config.xml file for ArcGIS Earth?
1212
04-27-2020 01:28 PM
JeremyBone
I am trying to setup a default view for ArcGIS Earth for a customer in another country.  I want to configure ArcGIS Earth to open to a default MapService and basemap already configured so they don't have to try and figure out how to step through and pick out a basemap.  We have a bit of a language barrier.  I have been looking at the config.xml, and I have tried to put in my MapService into the startupLayers section.  I have also tried to put it in the organizationalBasemaps section without any change.  Are there any other step by step instructions with some fictional examples on how I would configure this file available?
XuewenZhang
Hi Jeremy,
There is an online document to describe how to configure application parameters. Please check if this is helpful for you? Administrator configuration—ArcGIS Earth | Documentation
From your description, please be aware that there is a `visible` parameter. Please make sure its value is `True`.
If you still have issues, could you please help to figure out and share a screenshot? In this way, we could enhance the config description to make it more clear. Thanks.
Xuewen
JeremyBone
Great, thank you for the information, Xuewen!
