ArcMap with ArcGIS Earth
3595
05-13-2016 02:03 PM
BillGuiffre
Anyone have issues with ArcMap 10.1 not loading after installing ArcGIS Earth? Not sure if related or coincidence. User-defined breakpoint error occurring when trying to open ArcMap (ArcCatalog functions just fine).
DanPatterson_Retired
did this happen after installation or some time after?
from a previous thread, the software installs in administrator mode, so did you close everything, shut down everything, reboot then restart arcmap?
edit
since Earth is younger than 10.1, perhaps something in the install is not compatible, so check the system requirements for Earth to see if something was updated that isn't good for 10.1 System requirements—ArcGIS Runtime SDK for .NET | ArcGIS for Developers
JasmineDu
Hi Bill, are you using V1.0 or V1.1? Also, can you share some screenshots so the dev team can look into it? Thanks.
