ArcGIS Earth customize baseball card
1089
07-24-2020 01:44 PM
JustinDemers
Good afternoon,
I looking for documentation on how to customize ArcEarth Baseball cards. I understand that I can format each point by editing the html in properties but I am looking for ESRI documentation on this subject and tips from anyone whom may have experience in this. Would like to know if anyone has had any luck re-sizing the baseball card as well. Thank you!
XiChen
by Esri Contributor
Hey Justin,
Thanks for reaching out. To clarify the question, could you please describe the exact workflow of customizing Baseball cards? Are you trying to edit a KML data with Baseball cards info in ArcGIS Earth? If that's the case, please refer to this doc about the details of editing KML layer properties: Data support—ArcGIS Earth | Documentation
I also attach the text as below for your reference:
Edit KML layer properties by right-clicking the layer Properties in the table of contents:
  • General—Display KML layer information including name, appearance, and geometry type.
  • View—View and set the fly-to view.
  • Info—View and edit pop-up contents.
  • Refresh—Configure refresh mode and refresh rate for KML network links.
  • Location—Specify the bounding box of ground overlay.
  • Format—Specify the size and position of screen overlay.
Hope this helps!
CiCi
