I am using a high-resolution (0.5m) elevation tif as a terrain file, but ArcGIS Earth isn't reading it until I zoom in to an eye altitude below ~10,000m. Beyond that, it is showing an elevation of 0m.
@gherrman Thank you for bringing this issue into our attention. Could you help us pinpoint the issue by answering the following questions?
@gherrman can you confirm if this issue is still present in the most recent version of ArcGIS Earth? If so, could you please provide @Anonymous User further information so we can diagnose the issue? Thanks in advance.
@jsphillips, appears resolved in v1.18. Elevations show up to eye elevation of ~60,000 m which is definitely an acceptable point to cut elevation readings off at.
