Im using Drone2Map for creating 3D mesh from geotagged images. But drone2Map not creating a las points for some areas which is mostly vegetation. Since there is no las points in that place 3D mesh is not created/Elevated in that place. kindly suggest me h
1516
12-15-2017 05:21 AM
PrashanthMohan
Im using Drone2Map for creating 3D mesh from geotagged images. But drone2Map not creating a las points for some areas which is mostly vegetation. Since there is no las points in that place 3D mesh is not created/Elevated in that place. kindly suggest me how to create quality 3D mesh from Geotagged image with recommended parameter.
XanderBakker
Esri Esteemed Contributor
Where the images acquired using a Drone? What is the report indicating for key points overlap of the individual images? Have look at the quality check on the first page and see also this page for how to interpret the report: Processing report—Drone2Map for ArcGIS Help | ArcGIS  Do you have control points?
PrashanthMohan
Yes all these images are taken by drone.Control points are also there.Also 2352 2d keypoints are matching.
