Drone2Map Profile Plots stop working when you change the projects projection after processing
1151
11-05-2021 04:01 AM
SeanCullenZA
After processing drone images, the Profile Plot tool draws the profiles from the DSM and DTM appropriately.
If you change the project projection system the Profile Plots draw at an elevation of zero. Looks like D2M is unable to transform the line for the Profile Plot on the fly?
DanPatterson
MVP Esteemed Contributor
sounds related
Drone2Map changing Projection - Esri Community
... sort of retired...
SeanCullenZA
I can agree it is related.
Setting the Projection at the start of the project will remove complications. However if I then add GCP's (with a different GCS or PCS), I then need to change the project projection to use profile plots as the products and map space require the same Projection to draw successful Profile Plots.
I believe ArcGIS Pro can handle varying projections in Profile Plots. Could D2M not have the same functionality?
