Drone2Map Oepn in ArcGIS Pro
2310
07-05-2017 01:12 AM
승연__Seung-yeon_Jung_정
I upgraded Drone2Map 1.2 and try to use "Open in ArcGIS Pro" tool but I have this message showing. "Invalid input parameters: Missing Empty Aprx Path." Does anyone can help me with this? thanks.
GünterDörffel
All i can tell you: it works fine on my machine. I had used it with Pro 2 beta and now with  Pro 2.0 final.
JamesTaylor3
Esri Alum
   I'm one of the developers on Drone2Map and I'd be happy to take a look at this for you.  In the project folder there is folder:   C:\Users\<user>\Documents\Drone2Map Projects\<project_name>\products\GP\Open in ArcGIS Pro
Could you zip up this folder and send it to me?  I'll send my email in a private message.
jt
JamesTaylor3
Esri Alum
Steve,
  This is a bug caused by the language in your AGOL/Portal organization being set to Korean.  Most of the basemap names are in Korean:
We will fix this in the next release but for now you can work around this by selecting one of the Basemaps named in English (National Geographic or OpenStreetMap).   Once the project has been opened in ArcGIS Pro you can switch the basemap in the project to whatever basemap you want to use.
jt
