I have more than 10 different flights in different locations made with my drone (mavic2pro) and I am having a problem that I do not know why it is happening. When I configure the products that I want to obtain and the program begins to process everything, it generates almost all of them without problems. Both the DTM, DSM, Orthomosaic and point cloud in LAS and SLPK formats, generates them without problems. However, the product that interests me that is the MESH in SLPK format, generates a 1k file. The process ends without problems and without notifying me anything weird, but that product that as I say is the one that interests me, because I want a 3d scenario, it does not generate it. I send you a screenshot where you can see it.Hello everybody,My name is Andres Martin, this is the first time I write in the forum. I am having problems when generating multi lod mesh in slpk format with drone2map.
Andres
I've asked our development team about this, and we don't know any reason that this should happen. We have successfully processed Mavic Pro data in the past...
Can you contact support@esri.com and open a support ticket? We'd like to get a sample of your data if possible.
Cody B.
It's strange.
When I define the processing options, if in the tab 3d products I mark in general options 3d,
lod texture quality, medium and mesh reoslution medium, which is what comes by default,
it always generates a 1k file that has no information and no allows me to visualize anything.
After watching esri events webinar and hearing that it is advisable to mark in these two
high options, in this case, if it generates the mesh but, as I say, if I leave the medium option,
which is the one that comes by default, it generates me a 1k file.
I do not understand why. After watching the webinar, I repeated the process by checking both options,
high, and it came out but I find it strange that in the default medium option, I didn't generate anything. Tell me what you want me to send you. Thank you
I am experiencing the exact same problem. I want to like Drone2Map, because I would rather purchase it over Pix4D, but the textured mesh is main product that I need from the processing...
Has this issue been resolved?
