Color Balancing Failure
1006
08-14-2024 01:51 PM
JoshBerna
New error just dropped (for me). While adjusting images prior to check point image linking, I received an error during color calibration that ended the processing: "the raster is out of target space. its object id is 1."
This is my first time using checkpoints and I assume the issue is with the coordinate systems. I imagine the raster it is referring to is the first image in the table where it failed, as I did not have it set to create an ortho, just adjust images.
The Mavic 3E images were in WGS84 of course, and I defined the wgs84 vertical ellipsoid as well. The check  points were collected in wgs84 (horiz and vert) as well. My project output coord system is WGS84 UTM zone12N, WGS84 ellipsoid vertical datum. I have no problem importing the checkpoints and the images adjusted correctly otherwise. I really don't know how an image can be outside of the target area?
I mean, its not a huge deal if color balancing failed on this one. The entire flight was overcast. If I need color balancing in the future however, I would like for it to work. I have been unable to find this error online or any other mention of it. The entire error message word for word in google (with quotes) returns absolutely no results.
Anywho, hopefully this is blatantly obvious. I appreciate any help here, thank you.
