Drone2Map processing report export
4033
09-28-2016 04:55 AM
Status: Already Offered
Lars_ElmkærChwastek
It would be great to be able to export the processing report to a pdf, doc or another format for easy reading for other persons than the creator of the project.
4 Comments
LisaGibbons
Yes ! Please create an exportable report.
LAG155
The report is generated automatically, see the following address C:\Users\user\Documents\Drone2Map\Projects\NameProject\Report
MarkBuie
Thanks @LAG155 , that is correct. The report is generated automatically in the <project_name>/Report folder in PDF and HTML format.
Starting with with Drone2Map 2.2, you can easily access the report through the Manage pane by clicking 'Open Product Report' from the Processing Report dropdown.
CarlosRodriguez_LA
Confirming the report is exported on to the Report subfolder in the project location. Thanks for the info!
