D2M-Group Select Image Points in Map window
1999
09-23-2016 11:00 AM
Status: Implemented
by Anonymous User
Not applicable
Hi D2M Team,
It would be great to have the capability of drawing a box to group select image points that you would like to remove from the project before processing. Presenting you can do this from the Image Properties dialog box but when you are working with a large amount of images you have to go searching. Having the ability to visually identify and group select the points in the 2D view would simplify this.
Tags (1)
2 Comments
LisaGibbons
Yes, it is tedious to do one at a time when you require visualize of the photo points
AnthonyMason
