For ArcGIS Desktop,
Two options that I can suggest:
1. Download the PatchFinder.exe and run to see if any component is left.
2. Else remove the dirty files/folders/RegistryKeys manually
Rename or delete following folders:
C:\Program Files (x86)\ArcGIS
C:\Program Files (x86)\Esri
C:\Program Files (x86)\Common Files\ArcGIS
C:\Program Files (x86)\Common Files\Esri
C:\Program Files\ArcGIS
C:\Program Files\Esri
C:\Program Files\Common Files\ArcGIS
C:\Program Files\Common Files\Esri
C:\Program Data\Esri
C:\Program Data\ArcGIS
C:\Program Data\FLEXnet
C:\Users\<USERNAME>\AppData\Local\ESRI
C:\Users\<USERNAME>\AppData\Local\ArcGIS
C:\Users\<USERNAME>\AppData\Roaming\ESRI
C:\Users\<USERNAME>\AppData\Roaming\ArcGIS
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ArcGIS
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Esri
Go to regedit (RUN > REGEDIT) and rename/delete the following (if they exist):
HKEY_LOCAL_MACHINE\SOFTWARE\ESRI
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\ESRI
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Flex LM License Manager
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\<Delete Any Folder that contains ArcGIS or Esri>
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\ArcGIS Server
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\<Delete Any Folder that contains ArcGIS or Esri within>
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\FLEXnet Licensing Service
HKEY_CLASSES_ROOT\Installer\Products\<Delete Any Folder that contains ArcGIS or Esri within>
HKEY_CLASSES_ROOT\Installer\Assemblies\<Delete Any Folder that contains ArcGIS or Esri within>
HKEY_CLASSES_ROOT\<Delete and Folder that contains ArcGIS or Esri within>
HKEY_CLASSES_ROOT\Installer\Assemblies\Global\<Delete all Keys beginning with ESRI or ArcGIS>
Then REBOOT.
Think Location
