I am getting the following image when I try to open ArcMap
What can I do to fix it?
Thank you in advance
As it says... but go to Windows Control panel, find 'Install/remove programs' and invoke it and try a 'Repair' on the installation.
More importantly, assuming it worked at some time, you might be advised to uninstall whatever you installed prior to the failure or at least see if you can track down what happened between the good times and the bad times.
Thank you very much for your immediate response,
Windows 10 have been updated to my laptop, so I think that has something to do with it.
I just wanted to avoid the process of unistalling and installing the whole package of software.
I hoped that there would have been some kind of repair tool.
The windows 10 update didn't affect my computers at all. The repair process is painless and hopefully it works. It is the 'repair tool'
When you download media from My Esri, I always save the file to disk (sometimes a *.exe or a *.msi ... back them up somewhere else).
This just saves you the time of having to download it again. It is then a simple uninstall/reinstall if you backup any other settings associated with your profile.
I have the same issue in my machine. The very same message. Recently had a windows update also (took around 30-40 mins).
I solved the issue (i hope for good) by running the original ArcGIS Desktop 10.5 installation exe file and when I presented options (i.e., install/ repair/ modify etc...) I chose repair. It took around 15 minutes.
I have already obliged to do the "repair" procedure twice. The first time the problem has been "solved" for one day and then appered again. I will inform the community for the development of it. I hope that soon ESRI is going to realese some kind of Service Pack that will include solution for this problem.
Unfortunately, mine failed again-- I get the same "bad image message." I will try to run the "repair" function again, which I reckon will fail after a while. But indeed a service pack is needed ASAP.
Still the same issue. I had to reinstall everything but now the same issue. I will try to uninstall the most recent windows 10 update then reinstall ArcMap again.
We had a similar issue. Reinstalling ArcMap 10.5.1 many times worked for one day or so, and then again, the same bad image error.
Following the advise of an ESRI support analyst, we uninstalled ArcMap one more time and made a deeper cleaning by deleting folders and registry keys at
1. C:\ Program Files(*86) \ common files \ ArcGIS
2. C:\ program files(*86) \ ArcGIS \Desktop 3
3. C:\ users \ <User profile> \ AppData \ Roaming \ ESRI,
4. C:\ users \ <User profile> \ Documents \ ArcGIS,
5. Open your registry editor, HKEY_LocalMachine \ Software \ Wow6432Node \ ESRI
6. HKEY_CurrentUser \ Software \ ESRI
After that, we installed a previous version (10.4.1), which has been working without issues for a few days now.
In summary, we think that we have fixed the issue, but we are not sure if it was the deeper cleaning after uninstalling or just using the older version of ArcMap what solved the problem.
I hope this helps.
