Scott Sirotkin, *
From the FlexNet Publisher Licensing Administrators Guide (v11.13.0)
-158 Trusted storage open failure. Contact your publisher for further information.
Suspect it is a poisoned local FNP Trusted Storage cache on the client.
Check if navigating to the C:\ProgramData\FLEXnet and deleting:
ARCGIS_xxxxxxxx_tsf.data
ARCGIS_xxxxxxxx_tsf.data_backup.001
Then verify in Windows registry
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Environment that ARCGIS_LICENSE_FILE or LM_LICENSE_FILE **if present** are pointed to valid license servers.
Otherwise check the registry for Esri ArcGIS values in
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\ESRI\License10.3 that
LICENSE_SERVER value is pointing to a valid license server.
Then use ArcGIS Administrator -> Desktop -> Availability to see if licenses are available from the server.
If so, close Administrator and launch ArcCatalog. If that is good, open an ArcMap session.
Post back with outcome...
Stuart
