I have recently purchased a Microsoft Surface book and its got the 10.5.1 installation on and my mxds are stalling on opening the properties dialog box to go to change a font..have I not downloaded something extra?
Solved! Go to Solution.
Alice - I found something similar on the Esri Support Services site. The resolution for that particular crash was the following - "Edited ArcMap compatibility settings -> Navigate to C:\Program Files (x86)\ArcGIS\Desktop10.x\bin and right click on the ArcMap Icon and select Properties. Under Compatibility, change the application to execute in Windows 7 settings, if necessary. Also, check the box next to "Disable scaling on high DPI"."
You may want to try this to determine if ArcMap will respond normally.
Excellent - happy to hear! If you're satisfied with the solution, please mark my response as the correct answer so it closes the thread. Happy GIS'ing!
