How do I setup a database connection on ArcGIS server using Catalog to access an Oracle user-schema geodatabase?
514
07-25-2017 01:28 PM
BrandiKirchhoff
On my local computer, I have setup a database connection that uses an Oracle user-schema connection.  We have licensed a version of 10.5 ArcCatalog on our ArcGIS map server so that we can (hopefully) run Python scripts; however I am unable to setup the user-schema connection (it shows the schema in the Geodatabase Connection Properties window however the Owner of the transactional version is "SDE" and not the schema user).  How can I set up the user-schema geodatabase connection on the map server?  Thank you.
