The wizard was interrupted before ArcGIS 10.2.2 for Desktop could be completely installed.
7165
09-09-2014 09:34 AM
LindyNorén
Hi.
I keep getting this message when I try installing ArcGIS 10.2.2 :
"ArcGIS 10.2.2 for desktop Setup program Completed.
The wizard was interrupted before ArcGIS 10.2.2 for desktop could be completely installed.
Your system has not been modified. To complete installation at another time, please run setup again."
How should I proceed?
I can also mention that I have a Mac and I've installed an application that allows me to open windows-based programs.
Thanks.
V_StuartFoote
Lindy Norén‌,
We'll see if we can help you. But first we need some details about your OSX and the version of Windows that you have installed as there are a number of requirements that you must verify are met.
  Please let us know the version of OSX, are you on a Retina display?  Have you install VMWare Fusion or Parallels? Is this an attempt to run using WineBottler or another emulation?
Stuart
MarkosKapes
I'm currently using Parallels 10.3.0 with Windows 10 on OS 10.11.4, and I'm getting this error....
DjihaneGourari
Me too , i have the same issue when i tried to install ArcGIS 10.8 , what should i do ?
