severe (38): error during write
21093
7
04-17-2017 09:27 AM
moranmatanmatanmoran
Hey all
I install bootcamp on my airboocMAc and installed windows 10, that works great.
After that i downloaded arcgis 10.5 and arcgis pro, both working fine.
Problem is that once i try some options, like remove from current selection, i get this Visual Fortran run-time error:
  forrtl: severe (38): error during write, unit0, file conout$ image pc Routine line source DFOPRT.dll 6ba3a7a9 unknown unknown unknown
The arcgis just stops and then closed, when i do OK. I already did the admin successfully,  but the problem remain.
Dose anyone knows how to fix this ? it render my arcgis to an icon instead a gis program
Regards
Tags (1)
Hey
I found the answer to this problem (with help from Dan Patterson
The region time on my windows 10 user and arcgis user weren't the same.
Thanks a lot Dan!
DanPatterson_Retired
visual fortran error ... could be this one
LaviniaMmbaga
It has not worked for me. Kindly help.
PanGIS
Dan is right,
I have solved the same problem minutes ago as I had a PC that have been formatted recently.
Below, a visual update if case you have W10 as the link above stops at W7.
Thanks !
That did work - the region times weren't sync right
Hey
Thanks a lot Dan!
Glad I had the right answer... i guess
AltinTopalli
Can you tell me how do I fix this? How do I know what the region time on arcgis? If you could show me in more details, thank you.
