Only one UMN
12228
02-23-2015 06:34 AM
ModyBuchbinder
When a machine is not connected to the web the way to get a license is to create authorize.txt file or get the machine ID from the license manager. In all the machines I checked there are 2-3 lines of UMN (see screen shot).
We have one machine that we would like to install license manager on there is only one line.
ESRI cannot create a license file on this number. The authorize.txt has only one line too.
Does anybody have any idea what can be different on this machine and how to we get the second line?
Thanks
Mody
AndySmith
Hi Mody
What version of the LM are you using? Has the machine been upgraded from a previous version? If so what?
If you are using 10.3, it may be worth trying to uninstall 10.3, and install 10.2.x. Once that is installed and working, then try and upgrade from 10.2.x to 10.3. We have seen this resolve the issue before.
ModyBuchbinder
Hi Andy
Thanks for your response.
We just found out the LM 10.3 is not supported on server 2003 (it was supported for 10.2.2), this might be the problem.
It was installed without any warnings.
We already tried to clean the trusted storage and to reinstall the software – it did not help.
As far as I know this is the first time LM is installed on this machine.
Thanks
Mody
AndySmith
Hi Mody,
Yep, you will need to remain at 10.2.2 or upgrade the OS. 10.3 will not work on Server 2003.
