Network Analyst Toolbar will not display
1371
09-26-2017 12:15 PM
SheaO_Neill2
Hello Everyone,
I am using ArcMap Desktop 10.5.1. When I opened my computer today I found that I can no longer see the Network Analyst Toolbar. It is not grayed out, it simply will not pop up on my MXD whenever I click on the toolbar from Customize (or Customize Mode). I have tried resetting the toolbar, but this won't work either (see images below). All of the other Toolbars are working just fine. Only this tool gives me issues. Does anybody have any idea how to solve this?
DanPatterson_Retired
Check Customize Extensions to ensure that the extension is toggled on.
By chance that toolbar could be offscreen and you will have to search for it.  If you use a dual monitor, the fix is easy. otherwise you might have to try the alt tab thing or look around the edges for it.  Short of that renaming your Normal.mxt template in your profile might bring it back.
