Moving a license from one PC to another
2412
07-28-2014 08:19 AM
AaronGerber
I need to move a single use license from one PC to another. This is something that we accomplished in the past but have been unable to do so more recently. Any ideas?
ChristinaSullivan
Hi Aaron - I'm bumping this to Tina Skousen
V_StuartFoote
MVP Alum
Aaron Gerber‌,
Actually still easily done, but you will need to know the ESU authorization codes for the core Desktop product and each of the extensions.  All of them will often be found in an "authorization" file that should have an extension of *.prvc in email or on the local system.
The process is to run ArcGIS Administrator --> Support Operations --> and Deauthorize... it should return the fulfillments for the core ArcGIS for Desktop and any extensions, back to the FlexNet Publisher services at Esri Redlands.
Then, with the license "fulfillments" returned to Esri and available for reuse, you can use the same Authorization file and run the ArcGIS Administrator --> Desktop --> Authorize now... wizard.  You can manually edit the existing authorization file to remove extensions no longer needed, and could also just enter all the details by hand into the Wizard.
Proceed through and do the 'authorize now via the internet' for the simplest completion.
Post back if still stuck.
Stuart
TinaSkousen
Hi Aaron,
It looks like Stuart covered it.
If you're still having trouble, check here for un-installation:
Installing ArcGIS Desktop with a Floating License
and here for installation on your new PC:
Feel free to give us a call or send an email if we can assist further.
Best Regards,
Tina Skousen | Domestic Manager
Esri Customer Service| 380 New York St.| Redlands CA  92373
Phone: 888-377-4575 Option 2 for support
[email protected]
