Licensing 10.6 alongside 10.2.1
2133
07-13-2018 10:13 AM
TheodoreRakel
My client has 10 Desktop Advanced licenses for ArcGIS Desktop 10.2.1.  I'm testing installing ArcGIS Desktop 10.6 at the client's site.  I couldn't use the existing license server, so I installed License Manager 10.6.  I assume I need a new license file for at least 1 10.6 seat in order to continue.  Is that correct?  Can I use the client's existing license file in a 10.6 environment?
ModyBuchbinder
The EFL numbers did not changed between 10.1 and 10.6
10.2 client can use 10.6 license manager but as you found out client 10.6 cannot use license manager 10.2
The best way is to have one license manager in the newest version and then all clients can use it.
You can try to upgrade the 10.2 license manager to 10.6 and hope it will save the licenses.
A better way is to deauthorize the license from 10.2 and then authorize the same numbers on the 10.6 license manager
Have fun
ModyBuchbinder
Have fun
AmnoyAm
Mody,
You are not wrong with your assessment.  However, doing so will violate the customer license agreement.  If a customer stopped paying maintenance at version 10.2, the customer can only use ArcGIS Desktop and License Manager up to that version.  If you need to test ArcMap 10.6, you will need a license for 10.6 or higher.
