license manager
4302
7
08-11-2014 08:00 AM
sowmyaG
I dint get the license manager folder in the downloaded package of ArcGis 10.2.2 and  i couldnt change the host name to my pc . Can someone help me with this please??
curtvprice
Depending on your setup, the license manager may be a separate download. If you have the full DVD image, the license manager is in a folder (or can be accessed from the DVD startup menu).
DennisSmith
Were you able to figure out what you need to do to get the license manager updated and working?
TammyJohnson2
did you try going to the start menu?
start> all programs>ArcGIS>Liscense Manager
DennisSmith
If you have access to log into your 'My Organizations' found within the my.esri.com site, you can then access Products, Manage Downloads. Once here you can select the ArcGIS for Desktop version that you are looking at installing or have already installed and you will select the 'View Downloads' button under "Actions".  Once you are on the downloads page for the Deskti version, you can then scroll down and you will see the ArcGIS License Manager (Windows\Linux\Solaris) and then you can download the License Manager.
Let me know if you have any more questions that I may assist with.
Have a great day!
V_StuartFoote
Sowmya,
If you are working with a single use, or single use trial, license, you do not need and should not follow any instructions regards installation and activation and authorization of the license manager.
Are you working with a Single Use seat?
Stuart
DiegoLlamas
Hi Stuart, I am having some problem starting my LM 10.3 on my server. In the same server i have several License manager for other programs do your know if there is any incompatibility with LM for ArcGIS working on the same computer with other LM? because it worked fine in other computer that did not have LM. I want to have Centralized all my license on the same server. Thanks for your help and have a nice day!       manejadores de licencia.PNG
AndySmith
Hi Diego, this question is being answered for you in the following thread: License Manager 10.3 do not start
