Issues importing arcpy
2845
05-12-2016 10:32 AM
DanielBachmann1
I just tried to use arcpy from PyCharm and ran into the following problem.
After importing arcpy typing "arcpy." causes the following Error
  File "C:\Python27\ArcGIS10.2\lib\SocketServer.py", line 295, in _handle_request_noblock
Exception happened during processing of request from ('127.0.0.1', 8902)
    self.process_request(request, client_address)
  File "C:\Python27\ArcGIS10.2\lib\SocketServer.py", line 321, in process_request
    self.finish_request(request, client_address)
  File "C:\Python27\ArcGIS10.2\lib\SocketServer.py", line 334, in finish_request
    self.RequestHandlerClass(request, client_address, self)
  File "C:\Python27\ArcGIS10.2\lib\SocketServer.py", line 651, in __init__
    self.finish()
  File "C:\Python27\ArcGIS10.2\lib\SocketServer.py", line 710, in finish
    self.wfile.close()
  File "C:\Python27\ArcGIS10.2\lib\socket.py", line 279, in close
    self.flush()
  File "C:\Python27\ArcGIS10.2\lib\socket.py", line 303, in flush
    self._sock.sendall(view[write_offset:write_offset+buffer_size])
error: [Errno 10053]
I can use arcpy but there is no auto complete 😞
kr,
Daniel
DanPatterson_Retired
Pycharm has come up before with 'issues' and I don't know why, but check out your environments from a thread I posted before
https://community.esri.com/message/594720#comment-594720
and given you are using 10.2 and old 2.7, is this just a recent event, or this is the first time you have used pycharm instead of pythonwin, pyscripter or some other ide to test it against.
