Error Installing ArcGIS Desktop 10.8.1
9980
13
12-04-2020 05:20 AM
OlanrewajuLawal
I am trying to upgrade my ArcGIS 10.8 to 10.8.1. Once the installation starts the error (see attached image) shows up. However, I have installed and reinstall the missing Microsoft redistributable package.
I don't know what else to do.
Is there any suggestions on what to do?
Cheers
DanPatterson
MVP Esteemed Contributor
ArcGIS Desktop 10.8.x system requirements—System Requirements | Documentation
You met these conditions I presume AND you did a reboot between the download and running the msi?
... sort of retired...
OlanrewajuLawal
Yes, I didi
DanPatterson
Tech Support is your best option then.  Too many variables
curtvprice
I'm thinking your C++ redistributable may have an incompatibility with 10.8.1 (this can happen but it is rare). You could try downgrading. But if that doesn't work I agree tech support is where to go now.
Lkoman
Hello.
an esriBootstrap.log file should be located in your %temp% folder.  Please share that log file with me. This will provide us a little more information.
Thanks
Laurene Koman
Esri Install Team
Mike_Tulis
Hello Laurene,
We are having an identical problem but only with some of our computers, not all. ESRI Case #02781613 - ArcGIS 10.8.1 install issues with Microsoft Visual Studio C++ Redistributable error. Were you able to figure out what is going on?
Thank you.
Mike
Lkoman
Thanks
Laurene Koman
Esri Install Team
Mike_Tulis
Hello Laurene,
I have attached the requested file.
Thank you for your help.
Mike
Lkoman
Hey Mike
I don't see an attachment.  You can also mail it to me directly. [email protected]
