Debug ArcMap 10.3 start - process ends with 'Loading Document...' message.
9636
14
01-20-2016 07:14 AM
ValentinWittich
How can I debug the initial process of ArcMap 10.3.1 for Desktop? The ARCMAP.exe process get's killed after hanging a while with the "Loading Document..." message.
What I have done so far:
  • Check and reset the Normal.mxt
  • Reset AppData\Roaming\ESRI\Desktop10.3
  • reinstall ArcGIS 10.3.1
It seams like something is blocking the initialing process. Interesting is that the process gets about 70,000 K memory and then doesn't change anymore until it get killed. Any ideas how to debug the start of ArcMap?
ChrisSmith7
Honored Contributor
By chance, have you tried the MXD Doctor?
ValentinWittich
yes I did that too, but with a fresh installation it should be normally not a problem of the Normal.mxt itself...
JayantaPoddar
Try turning off the firewall/ Allowing ArcGIS applications through firewall
Think Location
ValentinWittich
I don't think the firewall is the problem. As ArcMap get a valid license status and I  can start ArcCatalog.
JayantaPoddar
This can result from an upgrade to Python 2.7.11, which was released on December 12, 2015.
Check this out...
45924 - ArcMap crashes during Loading Document launch stage
Think Location
ValentinWittich
I'll check that...
ValentinWittich
Unfortunately the  bug is not the problem, I use the first workaround but still the same result, ArcMap doesn't start.
JonMorris2
Bit of a long shot, but do you have any printers configured? Once a Windows update knocked out my printers and ArcMap wouldn't start. It checks the default printer on startup and if there is nothing there, crashes.
ValentinWittich
I'll check that too...
