Connect to Later version of Database server
1274
11-30-2016 08:35 AM
GideonDalrymple
Hi all!
I have a simple question which I just could find a direct answer searching on the internet. I am currently using ArcGIS Desktop 10.0. I would like to know if its possible to connect to a database server that was created using Catalog 10.4.1.
I have installed SQL 2008 and SQL 2012 is installed on the machine hosting that database.
regards
GIdeon
JayantaPoddar
Did you check these?
Client and geodatabase compatibility
Compatibility between ArcGIS clients and geodatabases in SQL Server
Also Note: The SQL Server Native client installed in the client machine should be of same or higher version to that of SQL Server Database.
Think Location
GideonDalrymple
Thanks Jayanta,
I don't see 10.0 listed so I guess I won't be able to connect to an enterprise geodatabase created from 10.4.1 right?
Client releasePersonal geodatabase release (ArcMap only)File geodatabase releaseEnterprise, workgroup, or desktop geodatabase using a direct connection*Enterprise geodatabase using an ArcSDE service connection
10.1
9.2, 9.3.x, 10, 10.1, 10.2.x, 10.3.x, 10.4.x
10.2.x
10.3.x
You can connect to 9.3 and 9.3.1 geodatabases to upgrade them.
10, 10.1, 10.2.x
10.4.x
10.1, 10.2.x 10.3.x, 10.4.x
10.1, 10.2.x
