Can't edit my geonet document
3499
8
07-20-2017 10:08 AM
curtvprice
I want to do an edit on my geonet document https://community.esri.com/docs/DOC-2077?sr=search&searchId=f0afadb3-da12-4afa-8b65-f64cbf9e84bd&sea...‌ and when I visit it I can't find an edit button. I am logged in and I am the author. Do old documents lose their editability? Did I lose my privileges because I am don't have enough cred in the https://community.esri.com/community/gis?sr=search&searchId=d239c74d-9564-4cc1-a6d6-41d7794609e6&sea...‌ place?
Tags (3)
TimothyHales
Esri Notable Contributor
Do you see the Edit button at the top right of the document?
curtvprice
No.
no edit button screenshot
DanPatterson_Retired
I do...
Did you move it there Curtis from somewhere else?  It is in version 10, so something is amiss
curtvprice
I don't believe I have have access to move anything anywhere, just share. Maybe if one of you superheroes moved it over to the Desktop Installation and Support space I will be able to edit it again.
your wish is granted
curtvprice
Thanks Tim, that did the trick: my Edit button appears now.
TimothyHales
Great!
