ArcGIS Desktop Icon
5544
6
05-20-2016 09:23 AM
SaraBelligoni
Hi everyone,
I am in the 60 days trial version, I have dowloaded ArcGIS Map and Desktop. Where to find the icon in order to start create new projects?
Thanks for your help!
DanPatterson_Retired
Assuming you are in windows, select the icon in the bottom left (start or similar), then select show all applications, navigate to ArcGIS and select ArcMap.  If you want an icon on the desktop or task bar, right-click on the menu option and select what you want
SaraBelligoni
Thank you for the reply.
But I need ArcGIS Pro, and not Map. the problem is that when I click on Pro, it asks me to log in and I do that with my credential for the online one but it tells me that I have no licence, so, what can I do?
Il Venerdì 20 Maggio 2016 18:43, Dan Patterson <[email protected]> ha scritto:
#yiv8039632013 * #yiv8039632013 a #yiv8039632013 body {font-family:Helvetica, Arial, sans-serif;}#yiv8039632013 #yiv8039632013 h1, #yiv8039632013 h2, #yiv8039632013 h3, #yiv8039632013 h4, #yiv8039632013 h5, #yiv8039632013 h6, #yiv8039632013 p, #yiv8039632013 hr {}#yiv8039632013 .yiv8039632013button td {}
GeoNet
ArcGIS Desktop Icon
reply from Dan Patterson in ArcGIS for Desktop Installation support - View the full discussionAssuming you are in windows, select the icon in the bottom left (start or similar), then select show all applications, navigate to ArcGIS and select ArcMap.  If you want an icon on the desktop or task bar, right-click on the menu option and select what you want
Reply to this message by replying to this email, or go to the message on GeoNet
Start a new discussion in ArcGIS for Desktop Installation support by email or at GeoNet
Following ArcGIS Desktop Icon in these streams: Inbox
This email was sent by GeoNet because you are a registered user.
You may unsubscribe instantly from GeoNet, or adjust email frequency in your email preferences |
Well you need to be licensed.  If you have a valid license for arcmap, then this shouldn't be an issue.  If you are with an educational institution or the like, then "they" have to give you permission to use the software since "credits" can be consumed and they don't want people floating around.  You will have to follow the procedures here
Get started with ArcGIS Pro—ArcGIS Pro | ArcGIS for Desktop and specifically here
Manage ArcGIS Pro licenses—ArcGIS Pro | ArcGIS for Desktop
SaraBelligoni
Actually I am the admin, so I don't understand why with my credentials it doesn't work, also because I can open and use Map without any problem...
Il ven, 20 mag, 2016 alle 19:02, Dan Patterson<[email protected]> ha scritto:
GeoNet
ArcGIS Desktop Icon
Well when pro 1.2 was issued, I had no problem installing, registering and using arcmap 10.4... pro 1.2, I had to wait until our admin received 'permissions' to use it and grant license access to the designated users... sooo, something along the path hasn't been completed and I would contact your regional rep to see what gives.
SaraBelligoni
Ok, thanks. I have disintalled in order to wait other info and try again following the entire process again. Anyway, I am in the free trial and I am the only one in using, as well as I am the admin with the permission to use ArcGIS Pro and the extensions.
Il ven, 20 mag, 2016 alle 19:17, Dan Patterson<[email protected]> ha scritto:
GeoNet
ArcGIS Desktop Icon
