ArcGIS (10.4) Slow Loading on Windows 10
30773
57
04-26-2016 09:05 AM
MichaelSnook
I have recently upgraded to Windows 10 and now opening ArcGIS (10.4) takes over a minute (1:36 last test) to load.  I have tried all of the usual tricks (delete normal, uninstall all add-ins, etc) with no luck.
Has anyone else had this problem?
Edit: Windows 10 installation was an upgrade from Windows 7 on a 64bit machine.  Windows was 'reset' after installation and all applications were removed.  ArcGIS 10.4, ArcEngine 10.4, & Background Geoprocessing were installed after the Windows reset.
Running i5-3470 4/core, 8GB, 120GB SSD
Thanks!
MichaelSnook
Thanks Stuart...I am going to look into all of these...could there be something specific to Windows 10 causing the latency?  Other machines in the office (running Win7 and 10.4 all hitting the same license manager) have 'no' issues.  Startup is quick.
Mike
DanPatterson_Retired
Michael, that why I was querying about standalone.. what I mean by that is a machine that has never participated in a shared environment at all.  ie no license manager, just a download install of ArcMap locally installed.
AdrianWelsh
MVP Honored Contributor
Michael,
Take a look at this thread:
Uninstalling/reinstalling Version 10.1
V Stuart Foote goes into some great detail on how to potentially combat these issues (related to 10.1 but I would presume the same processes apply - mainly the deleting of folders and registry items).
MichaelSnook
A note:  I recently started debugging an ArcGIS engine app that I have that was failing on the license initialization...(the reason is that I had not switched back to concurrent use from the single-use license).  After I switched back to a concurrent license all works fine, but, I put a break point on the license initialization portion and the app hangs (for about a minute and a half) which leads me to believe it's definitely an issue with the license manager communication.
It appears that after 10.1 you cannot start arcmap.exe with the /log option...does any one know a why to log (or at least trace somehow) the start up?
Thanks!
Mike
V_StuartFoote
Michael,
The "log" generated has never been especially verbose. But steps of KB44620​ remain functional for the 10.4 release.  What folks often miss is that the account running ArcMap.exe /Log must be able to write into the install directory where the executable resides and the log will be generated.
For more "complete" log details, you'll need to run sysinternals Process Monitor and filter.
Stuart
MichaelSnook
Yes.../log shows no useful info.  Sysinternals hasn't shown anything conclusive yet....only that the time line appears to be about 1.5 minutes to startup.  This is all the same with windows firewall turned off ...port 27000 is used.
Almost at the point of a total clean install of Windows 10.
V_StuartFoote
Michael,
Meaning the firewall was turned off on the license server, you're not referring to firewall on the client?
Otherwise any weirdness with your network traffic, native IPv6 or hybrid IPv4/IPv6 switches, what do nslookup and tracert reveal about the DNS lookup and routing from client to license server? And from license server to client? Any latency or odd routing?
Stuart
MichaelSnook
Yes...I have full access to the license manager server....nothing has changed on our network.  tracert/nslooup is normal and using the IP vs machine name doesn't affect anything.  I turned off IPv6 on the client but it also had no affect.  I'm really stumped....all other Windows 7 machines running 10.4, hitting the same license manager, start in less than 15 seconds.  It looks like the only option is to do a clean install of windows and test.
V_StuartFoote
Bummer, but last gasp before reloading the client workstation.  Create a new local account with administrative privileges and Launch ArcMap from it.  How does it do?
MichaelSnook
After much trial and error...I could not find a solution.  Thankfully the built-in reset process in Windows 10 if very easy (other than the fact that you have re-install everything).   I reset the Windows installation using the 'Remove and Clean' options and now all is working as expected.  ArcMap starts under 20 seconds.  Thanks all for the suggestions.
