ARC GIS 10 loads but will not open
9250
14
02-28-2012 03:12 PM
EamonSullivan
    I've being having a problem installing arc gis 10.  After downloading through a 1 year evaluation, when opening ARC MAP the program seems to just stall.
ARCMAP will open, initialize application... and stall. I uninstalled Arc GIS 9.3 for 10, my computer ran 9.3 just fine.
    I am not sure if it is a installation problem or a computer problem??? Any suggestions are deeply appreciated. Thanks for any help.
James
My computer currently running:
   Vista Premium 64 bit SP2
    Intel Core DUO 2.66 GHZ
    6.0 gb ram
    250 gb hard drive
    nvidia geforce gt 130m
V_StuartFoote
MVP Frequent Contributor
Cindy,
%APPDATA% environment variable depends on your operating system:
XP and prior  -->  C:\Documents and Settings\<username>\AppData\Roaming
Vista and newer --> C:\Users\<username>\AppData\Roaming    (hidden by default in Windows Explorer, but its there)
Always can confirm by entering "echo %APPDATA%" from a command window (cmd.exe)
Stuart
curtvprice
Talk about a FAQ -- I should probably sticky this, as keeping a clean app profile can resolve a lot of Desktop issues.
[thread=90076]Resetting your ArcGIS application profile[/thread]
Resetting your ArcGIS application profile‌  <- added link, 10/10/2014
SalmanAhmed
This thread that you suggested worked for me. Thanks!
BubbaHey
Thanks Curtis, very helpful.
PaulFrank
I also tried deleting ALL of the 3rd party applications, including FME, LP360, and others, and ArcMap finally opened, although it is still somewhat slow.  But at least I can open it.
There may be one 3rd party application that is slowing or preventing Arcmap from opening, so obviously delete one at a time, unless you want to delete all of them and reinstall what you need later.
Paul Frank
City of Austin
