After installing Desktop 10.5 prerelease, I could not install Desktop 10.5 final release
3996
9
12-29-2016 04:04 PM
JohnLadd
I installed Desktop 10.5 prerelease which worked fine.  When 10.5 final release became available I tried installing it and received error message that "another version of this product is already installed. Installation of this version cannot continue..."  I then uninstalled 10.5 prerelease and installed the new 10.5 final release but could not figure out how to authorize it.
JayantaPoddar
You need to do a clean uninstall of ArcGIS 10.5 pre-release before installing ArcGIS 10.5 final (including dirty folders and registry files). After uninstalling ArcGIS Desktop using uninstall utility/control panel, follow these steps.
Rename or delete following folders:
C:\Program Files (x86)\ArcGIS
 C:\Program Files (x86)\Esri
 C:\Program Files (x86)\Common Files\ArcGIS
 C:\Program Files (x86)\Common Files\Esri
 C:\Program Files\ArcGIS
 C:\Program Files\Esri
 C:\Program Files\Common Files\ArcGIS
 C:\Program Files\Common Files\Esri
 C:\Program Data\Esri
 C:\Program Data\ArcGIS
 C:\Program Data\FLEXnet
 C:\Users\<USERNAME>\AppData\Local\ESRI
 C:\Users\<USERNAME>\AppData\Local\ArcGIS
 C:\Users\<USERNAME>\AppData\Roaming\ESRI
 C:\Users\<USERNAME>\AppData\Roaming\ArcGIS
 C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ArcGIS
 C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Esri
Go to regedit (RUN > REGEDIT) and rename/delete the following (if they exist):
 HKEY_LOCAL_MACHINE\SOFTWARE\ESRI
 HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\ESRI
 HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Flex LM License Manager
 HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\<Delete Any Folder that contains ArcGIS or Esri>
 HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\ArcGIS Server
 HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\<Delete Any Folder that contains ArcGIS or Esri within>
 HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\FLEXnet Licensing Service
 HKEY_CLASSES_ROOT\Installer\Products\<Delete Any Folder that contains ArcGIS or Esri within>
 HKEY_CLASSES_ROOT\Installer\Assemblies\<Delete Any Folder that contains ArcGIS or Esri within>
 HKEY_CLASSES_ROOT\<Delete and Folder that contains ArcGIS or Esri within>
 HKEY_CLASSES_ROOT\Installer\Assemblies\Global\<Delete all Keys beginning with ESRI or ArcGIS>
Then REBOOT.
Think Location
curtvprice
Hey Jayanta, what is your source for these "ground zero" instructions?
RebeccaStrauch__GISP
Install ArcGIS Server on one machine—Installation Guides (10.5) | ArcGIS Enterprise
Obtaining an authorization file—Installation Guides (10.5) | ArcGIS Enterprise
You will need to create a Provisioning file using your myesri account for 10.5 Final.  The pre-release one will not work.  It's also called "ArcGIS Enterprise" now, but if you select the ArcGIS Server in the Product type, it will tell you that.
If you look in the Authorizations, you might see something like this when looking for the later version (use the filter)
And yes, you did need to uninstall pre-release before installing the final (that was mentioned somewhere in the pre-release docs).
JohnLadd
I can't create a Provisioning file, presumably, because I have no available Licenses according to my Authorization list.
Probably that is why the Software Authorization Wizard failed after my attempt to install 10.5 final.  Somehow I need to have ESRI acknowledge that I used licenses to install 10.5 prerelease for single use and, apparently, need new licenses to install 10.5 final.  Of course, all this may be unnecessary if there are no significant changes from prerelease to final release.
JohnLadd
attached is a copy of my authorization report. It's not clear how to
obtain authorizations to replace 10.5 prerelease with 10.5 final.
John Ladd
43 Hudson Watch Drive
Ossining, NY 10562
tel 914-923-1108 home
tel 914-907-2287 mobile
tel 585-204-0387 text
DanPatterson_Retired
Term License group... this wouldn't be an educational institution would it?
If so, you should really contact your internal manager of your licenses....
if not...
never mind
JohnLadd
No, my question is not related to an educational institution. I have a
single-use license for ArcGIS Desktop for personal, non-commercial use. I
would like to upgrade my software from 10.5 prerelease to 10.5 final. I
am told the first step is to obtain a Provisioning file which I can't seem
to do, apparently, because I have already used my 10.5 licenses.
John Ladd
Ossining, NY 10562
curtvprice
Rebecca, I think he wants a Desktop, not an Enterprise, license.
John, at least my single-use codes are the same for 10.1 - 10.5 and required no update.
I wonder which machine your license was farmed out to - you should run a Deauthorize in ArcGIS Administrator for that machine.
If your provision got locked up somehow, this is issue for Esri tech support.
JohnLadd
Yes, I am trying to update a single use installation of ArcGIS on my
personal laptop, the same laptop that I've been running ArcGIS on for
several years. I'll contact ESRI tech support - I thought all you guys who
were responding to my query were, somehow, connected to ESRI tech support.
Or,maybe, since the prerelease version is working just fine for me, I'll
wait until I need to renew my license in April. Thanks for all your
suggestions.
John Ladd
Ossining, NY 10562
