NOW AVAILABLE
Mapping and Charting Solutions 10.6.1 Patch 1
Published: 9/12/2018
This patch includes Esri Defense Mapping updates for the new JOG Data Product Specification (DPS) version 1.0. Updates included: JOG for TDS map templates; Visual Specifications; style files; grid XMLs; Production PDF XML; and the addition of JOG for TDS to the Rapid Graphic GP tool.
Enhancements and Issues Addressed with this Patch
Esri Defense Mapping - Desktop and Server
- Git391 : JOG Location Diagram - JOG_SHEETS_A labels are visible outside of the data frame.
- Git429 : JOG Margin Updates for DPS Draft v.0.2.
- Git468 : JOG Margin Symbol Updates.
- Git602 : Hydro Centerline licensing issue.
- Git611 : JOG Legend Updates.
- Git615 : Rapid Graphic fails if AOI Feature Class is in SDE and LandPoly is not.
- Git618 : Create Rapid Graphic causes python.exe to crash when exiting.
- Git620 : Need to add a new anno classes to Annotation features classes.
- Git621 : Update Geonames Layer file with the appropriate anno class names.
- Git629 : TM Template Labeling Expression errors.
- Git630 : TM VST Error for Grassland.
- Git632 : GeoNames_FeaturesP feature class in Geonames schema is missing NT field.
- Git633 : Add Symbol Level Settings for Roads in MTM templates.
- Git645 : Add Water Tower Symbol (TM & MTM).
- Git647 : Update JOG Meter Reference Guide element.
- Git651 : JOGA DPS/TDS7 Production PDF setting updates.
- Git652 : Update TM style for missing JOG symbols and add to VST.
- Git659 : Review and update MTM label expressions.
- Git660 : Update Rapid Graphic GP for new JOG product.
- Git661 : JOG DPS TEM Edits - TM.style and JOGA Margin.
- Git673 : Update alphabetical order in TM & MTM style files.
- Git674 : Add new parameter to Create Labels to Annotation.
- Git676 : Add new anno feature classes for data MTM and TM data frames.
- Git698 : Fix error in BuildingOffsets.py.
- Git709 : Storage Tank & Tower symbol for MTM and TM is missing white knockout.
- Git712 : Label expression error for layer BuildA - Blue072 for all MTM templates.
- Git713 : Missing Product class for TDS 7 product Library.
Esri Production Mapping - Desktop and Server
- Git486 : Unable to download data using WFS to Geodatabase.
- Git497 : Production PDF: Annotation halo colors are getting replaced unnecessarily.
- Git505 : Production PDF does not honor transparency for Character Marker Symbols.
- Git534 : ArcMap Prune Hydro GP Tool - Not Respecting All Compare Features.
- Git534 : Prune Hydro Not Respecting All Compare Features Issue.
- Git544 : Load Data GP tool does not update fields with default values on load.
- Git544 : Load Data using flat schema issue.
- Git643 : Production PDF spot color replacement is failing with layers.
- Git678 : Prune Hydro may crash when utilizing hierarchy field.
