I have configured "Report Feature" widget in web app builder using our newly configured Data Reviewer for server services. Everything works fines however when I try to save an "Visual reviewer Error" using Report Feature widget, I am receiving below error message.
Error Message on Web App:
Solved! Go to Solution.
Sounds like you are using a file geodatabase with your service. If so, the only operations that are supported are those which read from the workspace (such as dashboard and get results). You'll want to use an enterprise geodatabase for operations that create/write results. Here is a link to documentation that describes this limitation.
Thank you. It was very helpful.
