Tables with Domains
2397
10-27-2010 05:09 PM
TedCronin
Are tables supported for Domain Checking when a table has a Domain?  I just ran a Check it found 26 records, I can only Browse them (Reviewer Table Grayed Out), and it seems like the Browse is locked up.  I did just recently kill a process where the Browse was trying to Browse over 400,000 records, so perhaps there is something residual happening here.  I guess another kill is in order.
KumarBhardwaj
I tested this scenario on the latest beta build of Production Mapping 10 SP1 and I am not able to reproduce this issue.
I tested with a table with few records in it and the domain check is working fine with that and I am able write the errors in the reviewer table.
Please refer to the attached screenshot showing the reviewer table with the error record from a Domain check.
TedCronin
There may have been some residual processes going on at the time, so, next week I will retest, but then SP1 may be out for Data Reviewer, so maybe I wait.  It just seems like if It works for regular layers, it should also work with standalone, so no big deal.  Any word on SP1, Kumar.  I have a couple of posts on here about SP1.
Does Pro Services provide lists of bugs fixed and other info for SPs prior to release?
Also, remember Kumar, if you ever need some test data we can give you some.
MichelleJohnson
The Domain check does work with tables.  Thanks on your offer for test data.
TedCronin
Yep, I concur, I believe my initial testing was having issues due to my having to kill ArcGIS in an earlier testing scenario with FCs and Domains.  Domain checking works great on FCs, well small ones that is, but large ones not so much, hence it being killed and probably the reason I was having issues with Tables.  No Problem we got great and lots of, bad data, perfect for Reviewer, come and get some.  Dinner is served.
Also, no Esri tag for this user, hmmmm.
