Is there a size limit to calculate to the Reviewer Table? I am currently trying to write 26,000 features to the Review table and its not appearing to be progressing through the actual calculations. It is still showing 0 Reviewer results processed, and I have been here for the last 30 minutes. Perhaps another KILL is in order...
I am working with the Polyline or Path Closes on Self Check.
Is there a version number after ESRIProduction? E.g., HKEY_LOCAL_MACHINE\SOFTWARE\ESRIProduction\<version#>
Create a new key named Reviewer.
Create a new string value in Reviewer named MaxRecordLimit.
Modify the data value to the value you want.
Note: The higher the number, you increase the chances of having ArcMap crash. The new size limit will be dependent on your computer configuration and other applications you have running on it.
