Single Check Properties FC dropdown
2182
10-19-2010 10:14 AM
TedCronin
When using the Properties for a Single Check, if the user open the properties, and selects the Feature Class Dropdown, the first time the dropdown is selected, only one FC is listed, the second time the dropdown is pressed, all FCs are listed, shouldn't all get listed the first time.
TedCronin
Perf is pretty slow when validating 700,00 records, seems like this could get a bit faster.  Going on two hours, and I still have 50,000 + records left.
KumarBhardwaj
Thank you for reporting this issue, following bug has been logged for the same.
Bug ID: 3234
Name: Feature Class selection dropdown in Reviewer check properties shows different results on first and second click.
At this time the status of Bug ID : 3234 is "New". The tentative planned fix version has not yet been determined.
TedCronin
Thank you Kumar.
Not a big issue, just good to know you were able to repro.
