Issues using metacharacters in Regular Expression check
3767
01-28-2013 07:54 AM
KatieMcHugh1
I am trying to create regular expressions using metacharacters, but either I am doing something wrong or something isn't working.
My understanding is that the results of a regular expression check will produce the records where the regular expression is not
matched.
As an example of what I am doing:  I have a test feature class with a field that has 16 of the same value (ACEC), 2 of another
(Inholding) and 2 nulls. I think that using the expression ^[AC] should produce the records that do not begin with "AC".  Thus,
there should be 4 records in the results (the 2 "Inholding" and 2 nulls).  Instead the check results show all 20 records.
I have tried this with a variety of metacharacters, and have had no luck with any.  Is there something that I am not doing
correctly, or am I misunderstanding how to use these characters in a regular expression query?
Thank you,
katie
DanHopkins
Hi Katie,
Please construct the following regular expression:
AC[A-Za-z]*
What happens?
Regards,
Dan
TuanVu_Huu
Dear Dan,
I am Tuan from Esri Vietnam.
I am help customer in vietnam to build table check and I using Regular Expression check. I have try to check value field name of map sheet as like this : 6636-V-DN
And I have try expression as :
([0-9][0-9][0-9][0-9]-\[A-Z]-\[A-Z][A-Z])
But it is not return the error.
Moreover, when I have set some expression for other field it is work but it not check for NULL or Space value?
Please help!
Many thank in advance!
Vu Tuan
KatieMcHugh1
Hi Dan,
Sorry for my delayed response, I've been out for a few days.  That did what I wanted.  Is there any chance you could deconstruct
that for me so I understand how each of the characters are functioning?
Cheers,
katie
