Filtering Data Reviewer Errors by Feature Class in ArcGIS Pro
738
07-24-2025 06:29 AM
insertmaphere1
I’m a long-time ArcMap Data Reviewer user now working with attribute rules and Data Reviewer in ArcGIS Pro. I recently set up several validation checks in Pro to prep external sewer data (from 20+ agencies/cities) for our Utility Network migration. Each agency's data is stored in its own feature dataset inside a file geodatabase.
Here’s the issue: when I copy Data Reviewer checks across feature classes (e.g., manholes for City A to manholes for City B), running the checks pulls errors from all feature classes that have associated checks — even if I remove the layer from the map. I’m finding it overwhelming to filter through errors across every city/agency when I really just want to validate or inspect one feature class (e.g., City A manholes) without also seeing errors from City B or others.
Is there a way to limit what appears in the Error Inspector to a specific feature class or dataset? I’ve tried removing layers from the map, but it still lists errors for those feature classes. Any best practices or tips to streamline this cleanup effort by agency?
Thanks in advance!
LynnMoeEsri
I have been naming my checks to start with the name of the specific feature class or dataset and using a selection set.  Custom fields could help with this filtering.  If you are interested, watch the idea here.
