Error Opening Batch File(s). There was an error reading the batch file(s):
14419
27
08-31-2012 06:39 AM
ScottLampley
I am trying to open / view / edit a batch job file (.rbj) and get the following error:
The check will run but i cannot open it for editing...
The file in question is checking for a variety of geometry issues
This seems to have started after I upgraded from 10 to 10.1.
any ideas?
maherelayyan2
MichelleJohnson
Use the link in my previous reply.  It is to the PatchFinder utility.
The image just shows me you have ArcGIS Desktop 10.2.2, but does not tell me Data Reviewer version.  If you do not want to use the PatchFinder, then you can go to Customize>Extensions and click on Data Reviewer.
maherelayyan2
maherelayyan2
MichelleJohnson
Thanks.  I know people have upgraded ArcGIS Desktop not knowing that it does not upgrade DR.
Have you tried applying the DR 10.2.2 patch?
ArcGIS Data Reviewer 10.2.2 Patch 2 for (Desktop, Server) | Samples and Utilities
Or the other thing I would try is to uninstall Data Reviewer and Reinstall.
maherelayyan2
Is it a new patch ?because the file we installed is the latest given to us from ESRI Australia last month .
MichelleJohnson
That PatchFinder did not list the patch.  It should have if it was installed.
The patch I pointed you to was released Feb 6, 2014.  It's Data Reviewer 10.2.2 patch 2.
Here's a screenshot of patch finder on my desktop computer.
maherelayyan2
I will install it and tell you thanks
MichelleJohnson
I hope it works.  If not, try uninstalling and reinstalling.  I have 10.2.2 and 10.3.1 and have not had any issues creating and using my batch jobs.  If you don't get it working after the reinstall, follow up with tech support again.
Good Luck!
maherelayyan2
you are in in ESRI technical support ?
