Data reviewer not reply when I use writeResult function
4100
06-16-2015 05:52 AM
AmmarAssem1
I am working on DataReviewer 10.3 and when I am trying to write result by this URL : http://localhost:6080/arcgis/rest/services/reviewer/MapServer/exts/DataReviewerServer/ReviewerResult...
by using these parameters
          geometry : {"rings":[[[54.659932877000074,24.514610806000064],[54.659803389000047,24.514693374000046],[54.659893634000071,24.514811847000033],[54.660023122000041,24.514729278000061],[54.659932877000074,24.514610806000064]]],"spatialReference":{"wkid":4326,"latestWkid":4326}}
          reviewerAttributes : {"sessionId":1,"severity":2,"lifecycleStatus":10,"subtype":"","notes":"{10004252346}","reviewTechnician":"Ammar","reviewDateUtc":1434367161135.7983,"resourceName":"PLOT","reviewStatus":"new"}
The SOE doesn't replay with any message if success or fail but when I check the reviewer tables I have got a new record so the saving is done but I haven't got any response from SOE.
Ammar Assem.
KumarBhardwaj
Hi Ammar,
Please try the following :
1. Try restarting ArcGIS Server service.
2. Try using both html and json format?
3. What do you see when you submit the request? Did you get a blank page or nothing happens?
Kumar
AmmarAssem1
Hi Kumar,
Thanks for reply, I tried your steps by using html or json format but unfortunately  nothing is happen.
After submit the browser's loading image is working for about 3 minutes, after this the loading image disappear and no reply if success or fail.but when I use getResults soe function i see this feature has been added in reviewer tables.
Ammar Assem.
KumarBhardwaj
Hi Ammar,
I am not able to reproduce this issue at my end. Can you please contact Esri technical support here so that we can further troubleshoot this issue.
Kumar
