Data Reviewer Error HRESULT E_FAIL has been returned from a call to a COM compo
3110
07-02-2014 07:05 AM
KevinJenkins2
I kept receiving this error when running a Valency Check in Data Reviewer on a point and a line Feature Classes.  The line FC had many fields.  I selected to include all the fields when setting my properties, and then ran the reviewer and kept getting this message.  Unselecting "all fields" and keeping only the fields I truly needed resolved the problem.
Good Luck
Kevin Jenkins
KumarBhardwaj
Hi Kevin,
I request you to please confirm the following:
1. Version and Service pack level of ArcGIS Desktop?
2. Version and Service pack level of ArcGIS Data Reviewer?
3. What type of Data Workspace you are using? Is it SDE, File Geodatabase or Personal Geodatabase?
4. Are you running Valency Check through Batch Job or as Individual Check?
5. Can you also confirm if you are able to reproduce this issue with any other data?
I tried but not able to reproduce this issue at my end, if you are able to reproduce the same with any other data then I request you to please contact Esri Technical Support. We have to further investigate to find out the root cause of this issue.
Please refer to the following link to contact Esri Technical Support:
http://support.esri.com/phoneSupport#us
