Data reviewer batch job fails to return errors
8287
10
07-25-2012 09:41 AM
BethyRogers-Pachico
I seem to be encountering a bug in the data reviewer extension. Running a standalone check returns records; visual inspection shows they are true errors. Running the same check in a batch job does not return any records.
The check is a geometry on geometry check, with a SQL clause limiting each feature class, and a ???Not Within??? relationship.  A coworker wrote the same check from scratch and we ran the check on a different computer, with the same results.
Has anyone else encountered this?
DeanChauvin1
Brilliant!
As you stated, I used the spatial reference of the data to be validated as a parameter of arcpy.EnableDataReviewer_Reviewer and BOOM .... my geometry showed up as expected.
Thanks for the help!!!!
