Can I select error records from the map?
1292
03-06-2019 11:57 AM
ErinStrickler
Is there any way to select reviewer records by selecting reviewer geometry in the map?  I know I can edit the status of multiple errors at once, but I only seem to be able to do that by selecting multiple errors in the table. I want to be able to select the error geometry by location and change the status of these errors.
I'm using ArcMap and Data Reviewer 10.6.
Thanks!
AndrewVitale3
Hi Erin,
I have this same question. Were you able to figure it out on your own?
Andrew
ErinStrickler
No I have not. I'm starting to think it's just not possible, which is a
shame if it's true.
AndrewVitale3
I don't think it's possible either, and it really is a shame. I'm working with a large geodatabase that has never had QA/QC done to the geographic shapes, which means I've got over 15,000 data reviewer hits to sort through. Sure would be nice to address all of the issues in the map extent at once, rather than sorting through a giant table.
ErinStrickler
I have not used the grid functionality, but maybe that would help split your data into sections?
Thanks!
Erin Strickler
Cloudpoint Geographics, Inc.
(877) 377-8124
<http://www.cloudpointgeo.com/signup> www.cloudpointgeo.com
AndrewVitale3
Thanks for the tip. I'll look into it.
