Ad-hoc reviewer check doesn't return errors
1110
05-20-2021 01:42 PM
YukoOliver
I'm testing a data reviewer check (Duplicate Feature) on a line feature class in SDE in ArcGIS Pro using an ad-hoc check, but it doesn't return any errors even though there are duplicates in the data.
If I exported it to an FGDB, the check works, and if I ran the duplicate check via a batch job (created in ArcMap) on SDE, it worked.
Am I doing something wrong or is this bug?
KumarGaurav_Esri
Can you please provide some more details about this issue, I tested locally with a Polygon data in PostgresSQL database using Data Reviewer Duplicate Features Map rule and I got expected results.
Kumar Gaurav
