Data Sync between Cityworks, GDB, and Internal App
445
04-29-2026 11:42 AM
DawsonIngram
I am looking for assistance with migrating data that is/was in Cityworks with a Geodatabse. This data is needed in a GDB for use in Field Maps. Additionally, once certain components are updated/edited in Field Maps, I need this data synchronized with a separate internal application and oracle database. If possible, I would like to use the Data Interoperability tool we have access to as part of the workflow accomplish the data sync.
Thanks!
RenatoSalvaleon3
Hello @DawsonIngram. At the high level, Data Interoperability extension would be a good fit for this particular workflow. It sounds like the Cityworks data have been migrated to a geodatabase already so there may be no further need for a CityWorks Connector which is also available.
Do you have attachments on your Field maps feature service enabled and do you know if you need them imported into the destination?
I think it would be best if we give a short demo and some high level conversation of your workflow with the right people in your team.
I'll send you a note to discuss further.
RenatoSalvaleon3
DawsonIngram
Thank you for your quick reply. Yes, we have attachments enabled on the Field Maps feature service and would need any attachments (pictures, documents, etc.) imported to the destination. A demo and discussion of the workflow sounds good.
