Data Interoperability on Notebook Server
1441
06-20-2025 06:20 AM
Status: Open
Oiligriv
Hi
I didn't find anything online, could data interoperability be integrated into ArcGIS Notebook server?
5 Comments
BruceHarold
Hi Oiligriv
Depending on what you want to do, this might be already offered.  If you want to run a web tool on the same server then you should be able to import the toolbox and run it.  If you want to schedule a tool in a local tbx this should also work.  If you can share more details we'll be able to respond.
Oiligriv
if I use a script that calls a local toolbox (.tbx), which in turn runs a .fmw file (FME workspace), can I execute everything from my notebook machine (as the client), or does it have to be run from the server?
Thanks in advance!
BruceHarold
As far as I know, provided the ArcGIS Server machine hosting the notebook has Data Interoperability installed and licensed it should be available to the advanced runtime.  Best to check with arcpy.CheckExtension('DataInteroperability') before you invest a bunch of time in it - please let this thread know!
BruceHarold
I asked around, it looks like Data Interoperability can't be imported into ArcPy, this is what is available:
https://doc.arcgis.com/en/arcgis-online/reference/use-arcpy-in-your-notebook.htm
You could call a web tool though.
BruceHarold
Status changed to: Open
